Land Rover Owner International
CompetitionsEventsBuying GuidesFor SaleSubscribeLRO TVNewsHome
RegisterSearchFAQUsergroupsLog in
Reply to topic Page 1 of 1
V8 Distributor Dismantling
Author Message
Post V8 Distributor Dismantling
I have a electronic dizzy with a female pump drive and a points dizzy with a male pump drive. What I would like to do is use the electronic dizzy in my P5 Rover V8 engine, how easy is it to swap the shafts over. Does it need specialist tools, does anyone have a workshop manual for these dizzies?
View user's profile Send private message
Post
are the drive ends not a seperate part from the shaft?
Im sure I remember a roll pin and a seperate end but I might be thinking of something else?
_________________
1963 SIIA 2.25 P - in bits
1976 3 Door 3.5V8 R/R - just returning to service
2006 Nissan Navara!
2003 Freelander Td4 - hers
2000 Hanix H15B
View user's profile Send private message Visit poster's website
Post
The 'cog' does come off, held in by a pin. On the 'female' oil pump drive version the pump drive is a separate part, on the end of the cog( held on by another pin). On the 'male' version the end of the shaft is flat (like a screwdriver) and is recessed into the 'cog'. What do early Range Rover drivers do if they want electronic ignition? Looks as if I'm going to have to go with points until I find an answer.
Post
You can fit luminition to rid the points. Have a search for it on google
_________________
2006 Nissan Navara!
2000 Hanix H15B
Post
Had Luminition fitted to a 101 a few years ago, seemed to work well. Didn't know they still made them.
Display posts from previous:
You cannot post new topics
You cannot reply to topics
You can edit your posts
You cannot delete your posts
You cannot vote in polls
