Charging
One thing we all suffer from in our Landys are electrical problems. Got a problem or an answer - Post it here.
Charging
Postby davlyn » Tue 03 Jan 2012 3:08 pm
Good afternoon,
Can somebody let me know what voltage i should expect to see on a volt meter when placed across the live and earth terminal on my P38 diesel whilst the vehicle is ticking over.
Should it rise significantly when the engine is revved?
sorry if its a stupid question, I'm just trying to work out if the alternator is charging correctly before I fit a new battery.
I look forward to your reply,
Dave
davlyn
Spanner man
Re: Charging
Postby trex100 » Tue 03 Jan 2012 3:16 pm
you sould see any thing between 12-14 ish volts
when all electrics are on it should just got to just under 15 at the most even when reving
hope this helps figures are not exact
s111 88, s111 lightweight, 109 safari on galv (should have kept that one hey)
disco 300 tdi 3 dr
110 van 1986
110 tdi van 200
range rover 300tdi come 90 inch hybrid off road toy
disco 300 tdi xs
200tdi 1983 one ten station wagon (Project TOJ)
6 cylinder 1968 109 project 2012
trex100
Spanner man
Re: Charging
Postby jackdw » Tue 03 Jan 2012 6:37 pm
A fully charged battery should, in general, read out at 12.7 volts. When ticking over, or when revving quickly, it should rise to 14.4/14.5 and no more. Anything above will damage the battery, anything below and the battery won't be getting charged enough.
jackdw
Grease Monkey
Re: Charging
Postby pistnbroke » Tue 03 Jan 2012 8:07 pm
To be more specific.....First if you charge your battery and let it sit for 24 hrs then if you dont have 12.5v then the batterys is suspect.
Readings at idle and with lights etc on are meaningless ....go for a short drive and then without stopping the engine read the battery volts at about 2000 rpm ./ should settle to 14.4v . If below this then the voltage regulator is faulty.
This does not apply to ECU controlled alternators which need a different technique.
pistnbroke
Head suit
Return to Electrical
Users browsing this forum: No registered users and 2 guests
