7" LED sealed beam headlight unit housed in a die cast aluminium casing providing maximum heat dissipation and finished in black chrome. Featuring a high and low beam configuration with black reflector. Easy plug and play installation.
  • 9 - 36 volt
  • 8 x Cree (XML-10W) LEDs
  • Lumens 3800 high beam / 2800 low beam
  • Current draw (12v) 3.5 Amps high beam / 2.5 Amps low beam
  • 48 watt high beam / 32 watt low beam
  • E Mark approved
  • Rated IP67
  • Canbus decoder and H13 adaptors provided
  • Colour temperature 6000 - 6500k
  • Durable UV resistant polycarbonate lens
  • Die cast aluminium body
  • Stepless thermal management system built-in
  • Replaces standard 7" sealed beam / light units
