The 6-pot Landrover Defender Caliper is designed for use with 18” alloys and improves braking performance considerably whilst adding a touch of style to your vehicle.
By increasing the number of pistons from 4 to 6, increasing the pad surface area, improving the friction of the brake pad & using a larger vented disc we are able to transform your braking experience.
25% reduction in stopping distances
Improved pedal feel and driver experience
The Defender Brake Kit features…
  • Stainless Steel pistons and pins
  • Modern Fluid and dust seals
  • Sulphuric anodising in the colour of your choice for superior corrosion resistance – We stock the red kits as illustrated
  • Superior Holokrome 12.9 grade hi-tensile bolts
  • EBC Red Stuff brake pads for ease of replacement
  • Large Diameter Discs included
  • Full traceability of all manufactured parts back to the material origination
  • Extensive laboratory and track testing to prove performance and safety
Supplied with the following items
2 x 6 Pot Billet Brake Calipers – Anodised in red – Other colours available by special request
2 x 340mm vented discs
2 x brake pipes
These kits are a direct replacement
