Looking to replace the original plastic Td5 Defender coolant tank (which is prone to splitting like you've never seen before)? This TIG-welded item (p/n DA4751) uses the original pressure release screw cap and assists with cooling, as heat can radiate more easily - allowing the coolant tank expierence you really want.
Rather than coolant spraying eveywhere, your engine overheating, the cylinder-head gasket melting and your Land Rover leaving you stranded in the middle of nowhere to be eaten by wolves - this coolant tank is what you need. £152.99 is a small price to pay for keeping the wolves at bay.
