Owners of Series Land Rovers are often left out when kit is introduced, so it's good to see top-quality replacements being made. This fuel tank, a direct replacement for the standard front-fill ones fitted to Series II, IIA and IIIs, is made from 2.5mm aluminium - the base is 5mm for extra strength.
The tank is suitable for both petrol and diesel models. Thread inserts are included for the fittings for the pick-up, sender unit and return, and the filler and breather join with the standard hoses from the filler neck.
Neil says: 'You certainly won't suffer from rust in the fuel line again if you fit this.'
