Designed for quick and accurate tyre inflation with an in-line gauge, the ARB Inflator can be fitted to ARB compressors with a standard fitting, or the fitting can be removed and retrofitted with any air fitting using 1⁄4 NPT thread.
  • Compatible with ARB Air Compressors
  • Internal cut off valve
  • Easy to read dial with dual scale PSI/Bar increments
  • Quality bronze bourdon tube design
  • Fully geared solid brass precision movement
  • Protective rubber gauge guard
  • Air bleed button for deflating
  • 13" stainless braided flexible hose
  • Clip on chuck
  • 1⁄4 NPT US standard male air fitting
