A brand new specification Defender TD5, Puma 2.4 & Puma 2.2 TDCi Performance Intercooler compatible with cars with AC or non AC.
This HI-FLOW Intercooler is constructed using a hi-grade LM25 cast aluminium tank which is then CNC machined for a perfect fit to the centre cooling core – giving maximum strength when compared to folded plate end tanks. The very hi-spec centre cooling core is made to our desired specification and constructed with internal serrated and louvered finned tubes, which are designed to turbulate the internal charge air whilst giving a lower drop pressure across the core, also proving to be way more efficient than OEM, therefore yielding the maximum cooling effect; which is key to an efficient and balanced Intercooler package.
