Until now, the only ways to correct the castor angle on lifted Land Rovers have been to use either corrected radius arms or bushes. This kit includes new swivel balls, with the holes for bolting to the axle casing drilled to give 3° of castor correction, suitable for a lift of two inches. Manufactured by the OEM supplier and then machined, the kit is supplied with everything you need to change them over, including gaskets, seals, swivel in uppers and one-shot grease. The steering balls (DA3203) replace part number FRC7065 and are suitable for Defenders with chassis numbers LA to WA.
