Heavy Duty clutch
For Land Rover Defender 2.4/2.2 Tdci from 2007 to 2016
These clutches use commercial friction plate material, which is burst tested to 250 degrees C
The springs within the plate are also up rated by 20% (The springs are what causes many of the problems within the tdci clutches as they are not up to the job, this is what causes many of the rattles as the springs break up within the clutch plates)
The Clutch is Supplied with the Following:
1 x Clutch Plate
1 x Clutch Cover
1 x Release bearing (please note some 2.2 tdci models are fitted with a different type of release bearing, if the different type is fitted this will need to be purchased through a main agent)
PREMIER PUMA SEAT
RRP £1050.00 (per pair)
PREMIUM MODULAR SEATS
RRP £1026.00 (per pair)
