This KBX Land Rover Defender Front Grille & Lamp Surround Upgrade Kit is not only easy to fit, it's also capable of adding that extra beefy touch you have been looking for without resorting to using a grinder or a sledgehammer.
No drilling or special tools required for this grille kit, no sir! Easy to place on the existing Land Rover fittings and swap for the existing components, this kit is suitable for all Defender models - including those plush ones with that thing called 'air conditioning' - also covering those last of the line beauties from January 2016.
Constructed from tough injection moulded ABS (That's Acrylonitrile Butadiene Styrene, not the braking system or that thing Ryan Gosling has), once installed this will provide no issues whatsoever.
Grille panel is recessed to fit a Land Rover badge – supplied separately.
The Premium KBX Grilles arrives with a Stainless Steel diamond pattern woven wire backing mesh for the grille panel.
