The Land Rover Defender Lazer Grille allows for the stylish and sleek integration of Lazer High Performance LED driving lamps contained within a bespoke stainless steel lower front grille, which is suited to any Defender model with air-con and the standard (single fan) cooling pack. For vehicles without the air-con pack a separate grille surround is available to enable installation.
The grille simplifies installation of the Lazer lights, reducing fitting time, and with a matching complement lower, fender, and side grille parts also available; the design and look of your vehicle is enhanced while delivering superior auxiliary lighting performance.
Grilles are a woven mesh made from 316L stainless steel, and coated with a black nylon polymer to provide a long lasting bright finish with no risk of paint flaking or chips.
The grille can be fitted with 2x Lazer ST-4 or RS-4* lights, while the corresponding two-lamp harness kit with fully waterproof splice system for wiring into the vehicle electrical system without risk of damage or corrosion, will further simplify and enhance your auxiliary light installation. The grilles themselves are easy to fit with bespoke fittings and instructions, and because the grilles are custom-made the grille and lights will always remain secure and safe.
