AlliSport all aluminium TIG welded replacement radiator for TD5, 2.4 TDCi and 2.2 TDCI
Provides over 35% improved cooling and added durability due to stronger construction.
Standard radiators have crimped on plastic end tanks which are prone to failure.
Direct replacement, requiring no modifications to the vehicle.
Over 35% better cooling than standard using our special vacuum brazed cores and optimum 12 fins per inch (FPI) for maximum cooling.
Hand built and fully TIG welded in high grade aluminium to resist corrosion.
Less than half the weight of the standard item, but designed to withstand the rigours of harsh environments likely to be encountered by Land Rovers.
