Designed and produced exclusively for Exmoor Trim, this heater kit is supplied as a 2 seat kit with two x base pads and two x back pads and a cleverly designed wiring loom with handy short and high/low switch modules. We also include a clear fitting guide with easy to follow instructions. It also includes how to dismantle your seats and install heaters should you wish to install yourself.
The self adhesive pads are the exact size for Defender seats and thin enough not to show through the finished trim cover once installed. They are made from a very durable outer fabric that’s easy to bond and protects the seat and the internal heater wiring, from the rigours of Land Rover life!
The pad wires, once installed, leave the seat and plug together very simply beneath the seat base, out of sight,with all wiring encased in a tidy black tube finish that blends in with any interior. The main loom is simply taken to a live feed which can be direct or through the ignition process. Each seat has its own loom as opposed to a single feed.
The switches have a short end lead and plug to the main loom, this enables our switches to be fitted to the seats, console or dash with ease and a simple round hole allows the switches to be clicked into place.
The switches illuminate when ON with a 3 stage switch showing high setting, stand by and low setting and are thermostatically controlled with a pre-set temperature.
