Defender Short Shift  – Quick Shift – SHIFT-R
  • Fits Defender Tdci from 2007-2016
  • Shorter Gear Changes
  • Smoother Gear Changes
  • Reduced Vibrations – Vibrating gear stick is a common fault
  • Easy to Install – 4 Bolt Fitment
  • Comes complete and ready to install – The only item needed from the original gear stick is the gaiter at the bottom.
  • Fits Both RHD & LHD Models
  • Far more pleasurable driving experience.
  • Fit with all gear stick assemblies from original to aftermarket.
N.B. The Shift-R is manufactured to sit slightly closer to the cubby box, this enables gear changes to be a quicker and benefits the shorter throw. If you have a lock box fitted underneath your cubby box, the gear stick will fit very close.
