With a main plate machined from 6mm marine-grade aluminium, this steering guard is built to withstand knocks. The CNC-machined plate has 2.5mm radius curves on all forward-facing edges and is fixed to the chassis using two 5mm mild steel mounting brackets, which incorporate 16mm diameter lashing hoops. The kit is supplied with A2 stainless steel fasteners to secure the plate to the bracket and high-tensile 10.9 bolts to secure the guard to the chassis. The lashing hoops aren't designed for heavy recovery, but will accept a pull with a 10° cone in line with the chassis.
