The Devo-Tech suspension system has been specifically designed for Land Rover vehicles whether it be competition, overland or road based action.
Ultra-Lightweight for reduced unsprung mass
Maximum deflection in combination with smallest block heights
Exceptional block resistence and durability
Precision plan parallel and square end configurations under unloaded and loaded conditions
Lowest side loads with load centre ideally located relative to spring axis
Precision tolerances- the tightest in the industry
Highest linearity and guaranteed rate consistency
Each spring individually tested and rated
2" lifted spring for vehicles between 1900-2200kgs (twin winch set up, traybacked, tubular wings etc)
430mm free height
220 lbf/in
Front spring (can be used front and rear on balanced 100" tryaback models)
One pair supplied
