RRP: £1140.00
These front seats are sold in pairs only and are delivered ready to simply bolt in and use straight away, the seats arrive complete with runners as an entire new seat.
The seats are fitted as standard with Exmoor Trim seat heaters for both seat backs and bases including a full wiring loom and dash board switches with a high & low heat setting that switch on and off as they reach required temperature automatically. These switches can be installed either onto the dash or a centre console with the loom being plenty long enough for either. The loom has detachable plugs close to the base so you can remove the bases and unplug when required for service or under seat storage / battery access.
Pneumatic lumbars are also fitted to the seat backs on both the driver and passenger side which offer extra lumbar adjustment for the individual
The seat offers higher backrest with adjustable height headrest and side impact pads with superb style and comfort levels. The backrest is designed to hold you in around the hip and lower waist and then opening out leaving the shoulders free whilst supporting the frame. The seats will recline as normal and as with all Exmoor seats, they have removable seat bases for easy access to the under seat and battery storage unlike many other seats on the market .
The Extended Seat Base from Exmoor is much longer than the original seat bases fitted to all Defender Land Rovers. These new longer seat bases give superb support under the legs with standard raised sides for easy access. To install you simply clip out and clip in the new extended seat base it could not be easier. This is just what every Land Rover owner needs a bit better support on and off-road which you get with this high grade moulded internal foam for long life. These do give very good support for your legs, more so for the taller driver.
