Since many of today's new jerry cans vary ever so slightly in size (due tomanufacturing discrepancies), most fuel can mounting systems fail tosecure the cans properly. There is often wiggle room between the carrierand the can. And that gap, however slight, causes rattle and wear.  What's the point in strapping down your cans if they aren't trulysecure? The Front Runner jerry can holders offer a smart no rattle no wear solution.
  • The adjustable locking steel clasp means your cans can be secured firmly in place over a lifetime of off-road abuse.
  • The new bolt on top strap means provides greater convenience when removing the jerry can.
  • For use with 20l / 5.3 gallon NATO/Wedco style military cans. Will not work with Scepter style cans.
  • The steel strap downs cover the jerry can cap.
  • Add your own padlock and you'll never have to worry about stolen fuel while on the road.
  • Made of black powder coated 3CR12 stainless steel and is designed to easily bolt to the Front Runner Roof Racks using the flat slotted slats in the rack.
  • Can be bolted to any flat surface and can beused in a wide variety of applications such as mounting to pickup truckbeds or other brand roof racks.
  • Includes spacers for use with some of the new Carb Compliant Jerry cans.
  • No drilling required.
*Jerry Cans not included.
