Goodwinch TDS/KDS-10.0c with solenoid pack over the motor. 10,000 lbs c/w roller fairleads and wire rope. 173:1 ratio. This is a short version of the TDS winches with the brake inside the drum instead of the end of the gearbox. The ideal replacement for shorter offset winches.
  • Heavy duty series wound motor delivering high torque and fast line speed.
  • Three stage planetary gearbox giving a highly reliable and durable performance under the worst conditions.
  • The KDS-10.0 is equipped with the innovative Flanges braking system.
  • Rotating ring gear clutch with easy to operate freespooling lever.
  • Comes with standard wire rope 8.7mm x 30metres and roller fairleads.
  • As an option, Dyneema┬« Bowrope and Aluminium Hawse (10mm x 30 metres) is available.
