Made in the UK these are a modern, ultra strong, lighter weight alternative to heavy, corrosion prone metal sand ladders. These glass-reinforced polyester (GRP) TracMats are a must for any serious off-roader. Excellent for recovery use when stuck in thick mud or soft sand, or as a bridging ladder over narrow gaps which the vehicle wheel might not otherwise cross unaided. The waffles can be placed just under the front of the stationary tyre, and provide a non-slip surface for the vehicle to self-recover under it's own power, or in conjunction with another vehicle for assisted recovery.
The vehicle weight on the tyre is distributed throughout the area of the Tracmat, meaning the tyre will not sink or dig in.The Tracmat will deflect under the vehicle load, however, because they are made of a glass reinforced polymer rather than metal, the inherent elasticity allows them to spring back to their original shape when unladen. The excellent grip is achieved through the bi-directional mesh construction.This allows aggressive mud-tyre treads to easily grip and hold onto the surface. A quartz grit surface provides additional adhesion. This Combination creates unrivalled tyre to surface adhesion and grip greatly superior to any traditional metal sand ladder. The inherent strength, durability, reduced weight, and corrosion resistance makes Tracmats the only modern choice for the off-road adventurer.
50mm thick with a 50 x 50mm square mesh pattern. These "Heavy Duty Tracmats" are the real heavy weight champions. These big boys are ideal for the roughest terrain, with increased spanning and loading capabilities.
Available in yellow, green and grey.
