The KBX Land Rover Defender Front Grille & Lamp Surround Upgrade Kit is easy to fit using existing fittings – no drilling or special tools required, just a straight forward swap for the existing components.
The Kit is suitable for all Land Rover Defender models including air conditioned. *
Made from tough injection moulded ABS for a quality finish.
Designed on the latest 3D CAD system, allowing for improved air flow qualities, greater strength, fit & style.
Side and indicator lamps are semi recessed for added detail.
Grille panel is recessed to fit a Land Rover badge – Supplied separately.
The KBX logo is embossed in Grille and Lamp Surrounds.
Premium KBX Grilles come with a Stainless Steel diamond pattern woven wire backing mesh for the grille panel.
