The National Luna Split Charger Kit contains all that is required to fit a Split Charging System and comes complete with wiring diagrams, installation guide and full set of instructions.
Model Number S355
FEATURES:-
  1. Dual-battery isolator (intelligent solenoid)
  2. Dual battery controller (monitor)
  3. Twelve metres heavy-duty cable
  4. In-line power fuses
  5. Accessory fuse
  6. Cable lugs
  7. Battery terminals
  8. Screws
  9. Cable ties
  10. Instruction manual
 Specifications - Intelligent Soleniod
  1. Physical size - 128mm (l) x 113mm (w) x 70mm (h)
  2. Weight - 4.3 kgs typical
  3. Power supply- 8Vdc - 15Vdc (display range: 11.4V - 14.2V)
  4. Switched current - 85 amp (continuous), 400 amp (peak)
  5. Power consumption - 40mA ave (standby), 780mA max (solenoid engaged)
Specifications - Dual Controller
  1. Physical size - 107mm (l) x 48mm (w) x 20mm (h)
  2. Weight - 60 g
  4. Low-voltage warning - DC voltage below 11.4V
  5. Over-charge warning- DC voltage above 14.65V
  6. Cable - 3.5 metre 4-core cable
  7. Power consumption - 8mA (sleep mode-option) , 35mA Average , 40mA max
