Excellent performance for any vehicle that demands more from a battery. Optima batteries withstand high under-hood temperatures and can handle incredible amounts of vibration, which makes this battery perfect for any performance vehicle.
SC34R specs: 12V, 50Ah, Cold Cranking Amps (EN) 815 CCA, Reserve Capacity 104 minutes, Weight 17.2kg, Dimensions: 254mm long, 174mm wide, 200mm high.
OPTIMA RedTop Benefits:
- Lasts up to 2 times longer than other batteries.
- More power in the initial 1, 3, 5, and 10 seconds of the starting process than comparably rated conventional lead acid batteries.
- Constant performance quality keeping your battery running at the same level even as it's being discharged.
- Ideal for seasonal use, fully charged, it can sit unused for up to 12 months at room temperature (or below) and still start a car.
- 15 times more resistant to vibration than other batteries.
- Nonspillable and can mount in almost any position.
