Unbeatable performance for any vehicle with a lot of accessories such as running lights, high-performance stereo, winches, hydraulics or any number of things that demands more of your battery. Provides extra performance to meet your vehicle's demands.
SC34DA specs: 12V, 55Ah, Cold Cranking Amps (EN) 690 CCA, Capacity (EN) 55Ah, Reserve Capacity 120 minutes, Weight 19.7kg Dimensions: 254mm long, 174mm wide, 200mm high.
OPTIMA YellowTop Benefits:
- Dual Purpose starting and deep cycling.
- Lasts up to 2 times longer than other batteries.
- Constant performance quality keeping your battery running at the same level even as it's being discharged.
- More power in the initial 1, 3, 5, and 10 seconds of the starting process than comparably rated conventional lead acid batteries.
- Ideal for seasonal use, fully charged, it can sit unused for up to 12 months at room temperature (or below) and still start a car.
- 15 times more resistant to vibration than other batteries.
- Nonspillable and can mount in almost any position.
