This new quick release boss kit from Exmoor trim allows for added security and is very easy to release and unlock the steering wheel when parked.
The boss kit fits between the steering wheel and the standard mounting boss when upgrading your steering wheel, it does NOT however fit a standard Land Rover steering wheel direct.
When purchased with either a 36 or 48 spline boss you can then use the quick release and it fits very easily. These kits are supplied with all the stainless bolt fittings and allen key and also allows for horn push if required.
A high quality boss with a black finish and stainless internal casing with locking pin and dual action locking.
The diameter of the boss is 90mm and the mounting holes align with any Mountney or Exmoor Spline Boss. The width when installed and locked is 55mm which obviously does push the wheel closer to the driver but should not cause any issue, especially when used with a 13" to 15" wheel.
