Poorly aligned suspension can result in significant tyre wear. These dynamic-grade polyurethane bushes are designed to help your suspension retain alignment for longer as they don't compress like rubber bushes. The kit should give a compliant ride, even if your Range Rover is fitted with low-profile tyres.
This replacement bush kit contains the front and rear wishbone inner bushes for the front arms, and front and rear bushes for the rear upper and lower wishbones on an L322.
