This Revotec Land Rover Electronic Fan Conversion kit is an ideal replacement for the original viscous fan. Eliminate the engine warm up problems giving you a more effective heater, resulting in a better MPG & Performance on your engine.
Supplied in this kit is one of Revotec's most prestige products - our, Variable Electronic Fan Controller. This is a machined aluminium body with sealed electronics. Variable thermostatic control from 70°C to 120°C. This product is highly regarded as the best available on the current market. With no leaking.
We combine the latest waterproof fan and controller technology used together for the ultimate cooling package.
This kit is engineered to fit without any permanent modifications to your vehicle.
Kit Contains:
2x 12" High Power Suction fans,
Laser cut aluminium anodised fan mounting brackets,
35mm Revotec Electronic fan controller designed for Land Rovers with an extended loom,
Earth wire kit,
Bolts & fittings.
