This Revotec Land Rover Electronic Fan Conversion kit is an ideal replacement the original viscous fan. Eliminate the engine warm up problems giving you a more effective heater, resulting in a better MPG & Performance on your engine.
Supplied in this kit is one of Revotec's most prestige products - our, Variable Electronic Fan Controller. This is a machined aluminium body with sealed electronics. Variable thermostatic control from 70°C to 120°C. This product is highly regarded as the best available on the current market. With no leaking.
We combine the latest waterproof fan and controller technology used together for the ultimate cooling package.
This kit is engineered to fit without any permanent modifications to your vehicle.
Supplied complete with all necessary fittings and fixings to complete an electronic fan conversion on your Land Rover Defender/Discovery 200/300Tdi.
Each Kit Contains:
* A Revotec Variable Temperature controller. Recognised as the best available on the current market
* Variable from 70-120°C,Instant response, Minimal Obstruction to water flow. No Leaks.
* A High Power COMEX (Italian Made) Fan which is: Waterproof to IP68, Bearinged, Balanced and rated to operate 24hours.
* A set of Laser cut engineered brackets and all necessary fittings for a professional installation.
