This is the only front matting system available that is approved by Land Rover and the Ministry of Defence. This is the Kit. Already fitted to most military Land Rovers and used in extreme environments, this kit has proved itself to be up to the job time and time again. Supplied as a 3 piece kit with the floor & tunnel in one piece with the seat box totally covered and the bulk head centre. Approved at Millbrook testing ground and reduces the noise and heat levels in the front to below required safety standards.
The Grey Moulded Matting System has been specifically designed to increase ride comfort by greatly reducing heat and road noise. The 3 piece matting system is manufactured entirely from black cast dense polyurethane using precision injection mould tooling.
The Grey floor matt is a one piece floor section that covers the driver's / passenger's foot-wells and the gearbox tunnel. This design feature ensures maximum soundproofing and heat suppression.
The Grey one piece seat box cover encases the 3 open sides of the seat box to also greatly reduce noise and heat. Once the supplied firewall section is installed sound and heat reduction will be drastic.
The kit is available for Series IIs & IIIs standard gearbox and for all Defenders both with *LT77, R380 and *ZF Automatics & the new Puma
*NOTE: Some trimming is required when installing the Grey Moulded Matting Systems. The kit is also supplied with a bulkhead panel and the seat box cover is one piece and will require specific fitting.
Key Features:
Water repellent - Flame retardant- Black spec - Supplied as a 3 piece kit - Extra thick cast rubber on average1/2" thick - The whole mat is one piece from one side to the other - The bulkhead section is simple to install and is held in place by floor section - The driver's and passenger's foot well have noise suppression foam panels underneath - The seat box section is also one piece and will require cutting to suit your particular vehicle
