With the classic Land Rover logo and made to fit all 80" variants, left or right hand drive series one from 1948 to 1953.
To install you need to first clear the handbrake section trimming off by cutting away the lower groove, this allows the handbrake boot to sit very neatly onto the mat surface with the matting lipping underneath the boot.
The same applies to the pedal section, remove either the left hand pedal sections or the right hand depending on model type and the original boots again sit into the mat.
If you have the early chain pull on the right hand floor you need to simply punch a small hole in this thickened area to allow this to pass through the mat.
These are well thought out mats and fit very well and are in keeping with the era.
