RRP: £569.00-599.00
Our TDS_Goldfish Short Drum winches come in two sizes, either as a TDS-8.5c with a pulling capacity of 8,5oolbs, or a TDS-12.0c rated at 12,000lbs.
These brilliant waterproof winches have narrow drums which are ideally suited to trailer applications and both are 12 volt with a gear ratio of 254:1 giving control over speed.
Each winch is supplied with a 10mm x 23m (75′) Dyneema Bowrope and an aluminium Hawse, plus an Anderson quick disconnect fitting to suit a variety of either battery or towing vehicle harness.
Alternatively the winch unit may be bolted down to the trialer bed floor up against the headboard as in the case of the flatbed or beaver tail lorry.
* Towing vehicle harness to suit the vehicle c/w full harness, battery cut off switch, battery link, cable ties and rear Anderson quick disconnect fitting
