This workshop trolley hack (part number 1153CXHV) is finished in high-visibility green to make it easier to spot on your workshop floor. The 625mm long chassis adds stability and the three-tonne capacity makes it suitable for all current Land Rovers. The minimum saddle height is 130mm and it raises to a maximum of 435mm (17 inches), leaving a bit spare for most lifting purposes. The jack is fitted with a soft lifting pad to prevent damage, and the cranked lever makes it easier to give full pumps when the jack is located under the vehicle - like when you're lifting a beam-axle Land Rover on to stands. It weighs 19kg.
