Warn's all new heavyweight denier carry bag and medium duty accessory kit is what every offroader needs when they hit the trails.
Snatch Block
Used properly, the multi-purpose snatch block can double the pulling power of any winch, or change your pulling direction without damaging the wire rope. They also help to reduce heat build up and amp draw.
Tree Trunk Protector
Use this rigging strap along with a clevis/D-shackle to secure the winch wire rope to a wide variety of anchor points and objects. This strap is designed to help protect a live tree from the kind of damage a chocker chain or wire rope might cause. Constructed of tough, high quality nylon web encasing red warning marker to indicate damaged webbing. End loops are reinforced with abrasion-resistant wear pads.
Recovery Strap
Use a recovery strap to "snatch" or pull out a stuck vehicle. Nylon webbing absorbs the shock of heavy pulls, while the elastic rebound energy aids in quick recovery. Constructed of tough, high quality nylon web encasing a red warning marker to indicate damaged webbing. End loops are reinforced with abrasion resistant wear pads. Note: you should never use a recovery strap in a winching operation. For winching operations use a tree trunk protector strap or choker chain.
D-Shackles
The clevis D-shackle provides a means for connecting the looped ends of cables, straps and snatch blocks. The shackle's pin is threaded to allow easy removal.
Winching Gloves
All-new WARN winch gloves provide superior fit and protection. These gloves are designed to help protect your hands from the sharp barbs and abrasion that may occur when handling winch rope. Recommended equipment when working with winch rope.
Parts Included
20,000 lbs. (9072 kg) Maximum Capacity Snatch Block, with Grease Port
2" x 8' (5cm x 2.4m) Tree Trunk Protector, Rated to 14,400 lbs. (8165 kg) 2" x 30' (5cm x 9.1m) Standard Recovery Strap, Rated to 14,400 lbs. (8165 kg)
2 3/4" (20mm) D-sShackles
Heavyweight Denier Carry Bag
WARN Winching Gloves
